Login Error
PublicJake
After i login and do the verification code i get:
"message": "Unauthorized"
any idea?
2 REPLIES 2
Steve1975
Same here, I want to change my plan and this site seems to go down when it's needed. I honestly don't know why I stick with this provider. Half the time it seems the site is either really slow or down.
@PublicJake  Yes your not alone site is down for now try again in a hour , but the PM app is working can use it instead and update it if needed
