11-15-2022 03:04 PM
I set up a new account yesterday and can't get logged in. I tried changing the password and still can't get logged on.
11-16-2022 03:33 PM
Try using your phone number to reset your password, or try resetting your password through different web browsers. If not, try using the self-help chat.
11-15-2022 03:08 PM
try it once to use Private or Incognito browser mode and login using the password you just changed
If that does not work, then open ticket with PM Cs agent for help
at : https://publicmobile.ca/chatbot.
First type Forgot Login,
