12-02-2020 07:49 AM - edited 01-05-2022 04:20 PM
I’m locked out of my self serve account. Sent for a password reset, but it expired
12-17-2020 02:19 PM
@Pilonjames311 wrote:Locked out of self serve
Hi @Pilonjames311 the website was down earlier but it seems to be working now. Give it another try and see if you can log in now.
If you are still locked out of your account, try "Forgot Password"
I hope this helps.
Happy Holidays! 🎄🎄🎄
12-17-2020 02:06 PM
12-17-2020 02:05 PM
12-02-2020 07:59 AM
If password reset is not working, you will need to contact moderator.
To contact moderator via 2 methods:
Click on the question mark on the right lower corner of website to start ticketing process to contact moderator. Type: Contact moderator. Follow the prompts to submit ticket.
or
2 Send a private message to moderator through the following link :
12-02-2020 07:59 AM - edited 12-02-2020 07:59 AM
clear your browser history and cache and try the new password again
contact customer support mods if you're still having issues
make sure to check your inbox(top right corner envelope icon) periodically, for a response
