Locked out help
Matt13
since the new sign in screen came out I got locked out of my phone and I can’t make my payment because the code isn’t being sent to my email address
any help? Thanks
darlicious
@Matt13
The easiest course of action as suggested by @dust2dust  would be to make a payment by voucher using 611 or by calling 1855 4 PUBLIC and entering your 10-digit phone number. If you know your four digit account pin number you can use the credit card on file to make a payment. Otherwise you can enter a public mobile voucher 12 digit PIN code # to immediately reactivate your plan services.
You will then be able to receive the 2FA verification code sent via SMS text from public mobile. Once you log in if you go to your profile and you can disable the 2FA feature in your account. Then you can decide when you want to contact Public Mobile customer support in order to change your email or have the CSA look into what is causing the problem receiving emails from public mobile.
Here is more information on your payment options...
https://productioncommunity.publicmobile.ca/t5/Get-Support/Can-t-Make-a-Payment-or-Update-Your-Card-...
hTideFnow
@Matt13
use different browser,open incognito mode,clear cache,cookie, try Login
you still not work, open a ticket with PM CS_Agent. at : https://publicmobile.ca/chatbot.
type: Contact Us and Other
Finally Click here to submit a ticket
If you have error submitting a ticket, send a private message to the CS_Agent: https://productioncommunity.publicmobile.ca/t5/notes/composepage/note-to-user-id/22437
check inbox(top right corner envelope icon) for response from CS_Agent.
dust2dust
While you figure that out, you can buy vouchers and enter them in dialing 611. You can also use real time payments in some stores.
If you're suspended then you won't see the SMS option.
@Matt13
Try resend the 2FA code by text.
