Lock screen
CindyMtP
Lock screen and I forgot my password
Lg G8x thinq
@computergeek541
Good point, on my Samsung phone. I enable fingerprint, pattern and face recognition but disable Irises.
So if one fails, I can use the other security option to unlock my screen or phone.
@BKNS27 wrote:
@CindyMtP
Doesn’t the LG G8X ThinQ have a fingerprint sensor to unlock the phone screen?
I suspect that LG would do the same as some other manufacturers when it comes to fingerprint unlocking being disable any time the phone has been restarted.
@CindyMtP
hycm53
Lg G8x thinq
Wrong place to ask for help. Google it.
will13am
@CindyMtP , are you referring to your lock screen password?  Check out the following link on how to reset it.
https://support.google.com/a/answer/9043954?hl=en
If it is the self serve password that you are having issues with you can simply use the reset password feature from the login page.
