06-16-2022 01:34 PM
Hi ,
Why I was lockout from my account after two tries. Can my wait time of unlock can less than 3 hour?
My Account
06-16-2022 01:50 PM
HI @akbaig you need to get back before 3 hours?
Wait a full hour and try again
If still unable to login, open a ticket with PM Support immediately at : https://publicmobile.ca/chatbot.
(They usually reply within an hour, so, you should be able to get back in before 3 hours)
Follow this to get to ticket open screen quicker:
- First type: "Forgot log in information"
- Then Click "Contact Us"
- Finally Click "Click here to submit a ticket"
Once ticket is submitted, make sure to check your Community Inbox(top right corner envelope icon) periodically for response from PM's CS Agent
06-16-2022 01:37 PM
@akbaig it should be an hour then try again
06-16-2022 01:36 PM
Usually waiting an hour or so is sufficient.
