10-05-2021 08:17 PM - edited 01-06-2022 03:42 AM
Hello there,
There was recently an Android update sent to my phone in the last week. Since then, I have had little or no service while I haven't moved from my apartment. Can't find any help so here I am.
I've checked the APN and confirmed it's Public Mobile sp.mb.com
I've rebooted, turned off network and back on. Nothing gets it above 1 bar. Sometimes I get no reception at all.
Phone: OnePlus 6
Android Version: 11
OxygenOS 11.1.1.1
10-06-2021 11:02 AM
That's too bad - some good questions here that will help us clarify exactly what's going on from @esjliv... do you have call/text issues too, or only data (etc)?
Is "Oxygen" the standard OS for OnePlus? If it's a custom OS, then the process to downgrade should be simpler for you. One thing you can try is a factory reset of the entire phone. Make sure to backup all your contacts/data/photos/music/etc first. If that fails, then the manual downgrade process may be a good option, albeit a technically challenging one.
Have you tried swapping your SIM card into another phone, and another SIM card into your phone? This can confirm whether it's a phone issue or service issue. Occasionally, we see things happen when it really is just a coincidence and may not be an upgrade problem... let us know. 🙂
10-06-2021 09:05 AM
downgrade or uninstall the update is definitely a way to go .. except that.. phone does not have a easy uninstall /downgrade option, you have to download the old ROM and flash it with Odin3.. not everyone wants to go through this fun ride, i guess
10-06-2021 08:55 AM
The best option right now would be to downgrade back to the old OS and see if you get your reception back.
10-06-2021 08:19 AM
@patrickeleclair I have seen OnePlus users with different updates before. Someone reported that Nord 10 had issue on Koodo after August update. But yours is OnePlus 6, so it could be a different issue.
I suggest you try ask question at xdadeveloper forum or reddit and see if anyone had suggestions
Also, did you try to use SIM from another provider? Try with Rogers or Bell first. If they work fine, try with Koodo or Telus SIM
Lastly , you might want to try factory reset without restoring backup data first and see how it goes. Yes, it's painful to do factory reset but sometimes it's normal to fix issue after a update
10-05-2021 09:39 PM - edited 10-05-2021 09:42 PM
Does it work if you put the phone on 3G network only?
If not, can you try the SIM in another phone?
As last resort, maybe you could try a factory reset.
10-05-2021 08:53 PM
@patrickeleclair wrote:Hello there,
Phone: OnePlus 6
Android Version: 11
OxygenOS 11.1.1.1
Hello @patrickeleclair
Are you only having DATA issues, or calling and texting problems as well?
Are you able to check your SIM into another phone to see if issues persist? This would rule out your phone update.
If the Reset of your Network Settings did not do anything.
You could also try
Press and hold the Power button and Volume up key until the device powers off. This can take up to 30 seconds.
Here are the APN settings for your model, check it against what you have, or reenter them:
https://apn-canada.gishan.net/en/apn/public-mobile/oneplus-6
10-05-2021 08:51 PM - edited 10-05-2021 08:52 PM
you can try reseat the SIM card and Make sure your phone is off before removing your SIM card,
1. power off your device
2. take out the SIM card,
3. waiting a 1 minute,
4. put it back and power on,
5. toggling airplane mode off/on,
and do again Rebooting your phone,
and if is still not fix it try in another device to test your SIM card is no issue on it
and try to do Restore Factory Settings,
10-05-2021 08:37 PM
Right on. I'm using this now, it has me at -106 to -101 while sometimes going up to -70. Not sure how I can use this information to help but I like putting a number to an issue.
I understand the update shouldn't change my signal but those 2 changed at the same time. I live in a large enough city so I'm not sure what else to do.
10-05-2021 08:32 PM
@patrickeleclair , I like to use this app to troubleshoot connectivity issues. The app will tell you which tower you are connecting to. If the tower is really far away, it can explain the low signal strength. I doubt the OS update has anything to do with the problems with you are currently experience. As for APN, that only affects mobile data if the information is incorrect. It does not affect the general connectivity to the cell network.
https://play.google.com/store/apps/details?id=com.wilysis.cellinfolite&hl=en_CA&gl=US
10-05-2021 08:30 PM
Tried this, no change.
10-05-2021 08:20 PM - edited 10-05-2021 08:20 PM
, How to reset network settings on an Android device
or visit Here link,
and go Changing APN Settings On Android device
click Here link,
and do Rebooting your phone,
*what is mean for Rebooting the phone means to turn off your phone and turn it back on again.
