Linked to old number
Kirsten3
I had an account with an old number, I didn't;t use it for a year as I moved out of the country. When I returned I opened a new account and got a new number. I no longer have access to the old number. To log into my account it is sending. code to the old number... How do I fix this???
1 REPLY 1
hi @Kirsten3
you won't be able to get the old number back, you lost it too long ago
So, you need to setup PM as a new account.  if you use the email to setup the new account but some how the system tries to send 2FA to the old number, the best way is to use another email to setup that new account.  But if you want to keep using the same email, then ask PM agent to check and help
 you can submit  ticket by direct message:
