04-19-2022 12:20 PM
Hi,
I tried transfering my line from rogers to Public and it seems rogers did not get the confirmation text, now I need public to send another line transfer request. Does anyone know how to get that done?
04-19-2022 02:04 PM
Another indication of completion is that with the old sim in the whole time you'll eventually get a text saying it's done. Then switch out the sims. Just another option.
04-19-2022 01:59 PM - edited 04-19-2022 01:59 PM
It's easiest to just call the telus porting department with the phone # supplied by @Yummy using your rogers SIM card. Give them your rogers account #. You will receive the PAT (porting authorization text ) within a few minutes and reply YES. Remove the rogers sim card and replace it with your pm sim card. Reboot. The port should complete within about a half hour at most but can take up to 2 hours to complete. Your rogers sim will cease functioning and account will be cancelled once complete and incoming calling will be recieved on your pm sim card.
To pre-verify your account include in your private messaging only your full name, address, email, phone # and 4 digit acct pin #
04-19-2022 12:36 PM
04-19-2022 12:26 PM - edited 04-19-2022 12:40 PM
If you did not get SMS from Rogers when you initiated porting to PM, you have to ask agent to re-initiate porting request.
Or you can call number I sent you for porting assistance.
Use the ticketing system for a faster response time (preferred method as Ticket is assigned and easy to follow up with CSA). Click Chatbot - Ticket and type ticket, then click on Contact Us, then click on issue you inquire about. Link for creating ticket will be presented.
- Send a private message to the CSA - agent by clicking Here
