04-04-2017 03:08 PM - edited 01-04-2022 01:38 PM
04-04-2017 05:26 PM
04-04-2017 05:22 PM
04-04-2017 05:20 PM
04-04-2017 05:19 PM
04-04-2017 04:59 PM
04-04-2017 04:08 PM
@Muskokarob I don't believe you can buy another of the same add-on until the 10 days are up, unfortunately.
04-04-2017 03:15 PM
What exactly did you buy?
The data options are:
U.S. Data Only for 10 days.
Once the data is used up the service stops. You would then need to buy more if you exceed the limit you bought for
