4 weeks ago
I switched to another provider. I need the public mobile last invoice . I realised i do not access to my account via the app anymore. Please help.
Thank you
4 weeks ago
there is no last invoice. Whatever your last renewal cost...that's the last as you ported your number away and your account was deactivated. To reach Customer Support, use this link...
4 weeks ago
hi @Didije
you will need to ask PM support to prepare you the invoices, you can submit ticket by direct message:
4 weeks ago
Only PM can help you if you account is closed
open ticket, then message PM using this link:
