LOST SIM
mtim20001
Hello everyone,
Need help. My family's member lost PM's SIM card during travel.  We were unable to login into the Account. the only options on "Resend Code" are: Send via Text or Send via Voice Message. Does not matter how many time we click "Resend the Code" or types incorrect codes,  no "Send via Email" option shows up.
Can support help with this ?
Thanks.
mtim20001
I don't see this option: "didn't get the code?".
Clicking on 'Resend Code" show me this:
Waiting on timer to expire shows "Code Expired"
Entering invalid code more than 3 times  results in empty screen
Tried in Chrome and Firefox  both in Private/Incognito modes.
I sent Private message as suggested by @kb_mv
HALIMACS
@mtim20001
After you've regained access to the self-serve through that option, place the account in "Lost /stolen mode" then acquire a new PM SIM card either at a corporate Telus or Koodo location and you can change the associated SIM card attached to the account in your profile tab in self-serve.
This way you retain the number and the account particulars as opposed to creating a whole new account and starting from scratch and losing the number.
After you change the associated SIM card number, remove the account from the Lost/stolen designation.
@mtim20001
you should be presented with an option which reads "didn't get the code?"
If you tap on that it will give you the option to receive it through the registered email on the account
mtim20001
Thank you. I will do that.
kb_mv
@mtim20001
Contact a Customer Service Rep, you can send them a private message at the link below. Hopefully they can help you out.
You should receive a reply within 48 hours though they are typically much faster. Keep an eye on the envelope icon for replies.
