LOST MY PHONE. NEED TO REPLACE SIM
09-11-2017 05:33 PM - edited 01-05-2022 03:14 AM
I misplaced my phone at work and cannot find it. If i get a new Sim card from walmart how do i register it as a new sim card?? What steps do i need to do
thank you
Service
09-11-2017 05:39 PM
@minkib9, sorry to hear about your lsot phone. You will need to go into your acount and register your current sim as lost under lost phone. Or if you are purchasing a new sim right away you can just get your new sim and go into yoru account and choose the Change Sim option and you will then enter your new SIM card number and it should activate and de-activate your old sim.
![](/skins/images/34AB3B0FE78BBE11DBF186F131BC3766/responsive_peak/images/icon_anonymous_message.png)
