12-19-2021 02:09 PM - edited 01-04-2022 04:53 AM
Hi,
I'm in Canada and activated the holiday bonuses - long distance minutes and data.
I'm flying to Hawaii tomorrow and would like to be able to receive calls there.
Does the 500min free Long Distance calling Add-on only work if calling or receiving calls from within Canada? Or will it still work (receiving/making calls) from within HI?
Or will I need to purchase a US roaming add-on to make/receive calls in Hawaii?
Thanks
12-19-2021 02:28 PM
@ca : As a curiosity, if you do wait to purchase talk roaming, try calling your number somehow when there. I think there might be a "grace" inbound or two until it doesn't.
Never mind if you buy it before.
12-19-2021 02:12 PM - edited 12-19-2021 02:12 PM
For Holiday Bonus used in canada only and you need to Purchase Add-Ons
For US Roaming 10 day packages
Unlimited U.S. Talk, Text and 250MB Data Bundle = $20
Unlimited U.S. Talk and Text Bundle = $15
Unlimited U.S. Talk Only = $8
Unlimited U.S. Text Only = $8
U.S. Data Only 10 day packages
250MB = $10
500MB = $15
1GB = $20
when you visit U.S. and then Purchase it,
sign in to Self-Serve, to review your account, if you found at Available Funds: $$
Try To Purchase Add-Ons Using Your Self-Serve Account
Follow these steps:
after purchase successful you have to do Rebooting your phone
what is meant by rebooting the device turn off and turn it back on.
review of Add-ons visit Here link...
make sure enable roaming on,
Try manually selecting either of AT&T or T-Mobile, whichever works best for you,
for Re-Purchase Add-ons you need to wait 25 hours after the expiry first Purchase Add-ons or you need to Contact Customer Support Agent by CS_Agent, to do it for you....
12-19-2021 02:10 PM - edited 12-19-2021 02:16 PM
Sorry you'll have to get a roaming add on to use while you're in the USA.
Those free long distance minutes will only work if you're calling from within Canada.
If you use a VoIP app like Text Now and have access to free WIFI, you'll be able to use that for free to call and text, while you're in HI.
