01-09-2020 02:30 PM - edited 01-05-2022 08:57 AM
We are considering this smartwatch for our son. Can this be set up on your service with the $15/month plan?
04-23-2022 02:54 PM
04-19-2021 08:43 PM
I realize this is 15+ months old but ... did you get the watch? If yes, did it work?
01-09-2020 05:27 PM
@ryangoldvine wrote:
https://www.myticktalk.com/products/ticktalk-3
I'm not sure if you know this, but the $179.99 is American dollars which means it costs around $233 CAD without tax or shipping.
01-09-2020 04:23 PM
If it is compatible with Telus, Bell 3G bands, then it will work.
01-09-2020 03:58 PM - edited 01-09-2020 04:24 PM
@ryangoldvine wrote:We are considering this smartwatch for our son. Can this be set up on your service with the $15/month plan?
@ryangoldvine Yes it will work. Just make sure you pick the 3rd option when ordering "Your own local carrier" The watch supports a nano sim card and all the necessary bands to work with Public Mobile.
Product Specs from their website:
Product Size: 43.5 × 44.5 × 17 mm
CPU: MT 6737
Ram/ Rom: 1G/ 8G
Antenna: LDS
SIM Card: Nano
LCD Size: 1.54 inches, TFT
LCD Resolution: 320 × 320 dpi
Camera Resolution: 2 Million
Waterprove: IP67
Battery: 680mAh
Standby Time: 1.5 Days
Input: 350 mAh / 5V
Bands:
4G
B1/ 2100
B2/ 1900
B3/ 1800
B4/ 1700
B5/ 850
B7/ 2600
B40/ 2300
3G
B1/ 2100
B2/ 1900
B4/ 1700
B5/ 850
01-09-2020 03:00 PM - edited 01-09-2020 03:01 PM
@ryangoldvine The company claims it does. Uses a nano SIM. Allows APN settings. Public Mobile is listed as compatible.https://www.myticktalk.com/pages/t3-carriers
Tread carefully!
01-09-2020 02:50 PM
If you look into specifications you will see that 3g bands include those of telus/bell and most common 4g bands are there, so i see no reason why wouldn't that watch get on public mobile network
01-09-2020 02:46 PM
Only if the smartwatch has its own SIM card. There is no support for eSIM. It MUST support at least PM's 3G network frequencies:
4G LTE/LTE Advanced: 700 MHz, 850 MHz, 1900 MHz; 2100 MHz downlink with 1700 MHz uplink (AWS).
HSPA (3G): 850 MHz, 1900 MHz (UMTS).
01-09-2020 02:46 PM
Just to add on to my own comment:
I just sent the chat a message and they mentioned that they currently did not have any users using public mobile but they do know it works with Lucky mobile which is Bell's version of Public from the sounds of things. So my best guess is that it should work with Public.
Hope that helps!
Thanks
01-09-2020 02:42 PM
Hello,
Your best bet would likely be to ask the actual company. Just from quickly scrolling on the website I saw something about a list of compatible carriers and it seemed to just include american companies. There also seems to be a chat feature on the link you provided! Hopefully they would be able to give a bit more information.
https://www.publicmobile.ca/en/bc/get-started
There is also a quick thing about seeing if your device is compatible in this section of the website. Maybe check out if the watch is listed?
Good luck!
