Keep my plan and get a new number after porting my number to another carrier
03-01-2018 04:01 PM - edited 01-04-2022 03:38 PM
Hi,
Currently I'm with Public Mobile.
I will get a company phone and plan. I will port my number to the company plan( probably Telus).
Can I keep my public mobile plan and get a new phone no.?
How to do it?
Do I need a new sim or I can reuse my current sim and just change phone no.?
Thanks
Jeff
03-01-2018 05:22 PM
@ShawnC13wrote:
@will13amwrote:Personally, I would not mix work and personal stuff. Keep the personal plan for personal use and the work plan for work. Unless it is a requirement of the job, why carry a company phone around 24/7?
Totally agree with you but I do have a separate phone and am "supposed" to have it with me at all times
You have my sympathy. Although I can keep some nasty hours at the salt mine, generally what happens there stays there.
03-01-2018 04:18 PM
03-01-2018 04:15 PM
03-01-2018 04:07 PM
@baraquewrote:Hi,
How to do it?
Thanks
Jeff
Sorry to tell you Jeff, this isn't possible anymore. Once you port out your phone number your account gets closed. If you change your number before porting you lose your number.
