08-07-2018 07:04 PM - edited 01-05-2022 05:18 AM
No matter how many times I tried, when setting up account, it would NOT allow me to add my friend in the referal portion.
Please help!
08-07-2018 07:47 PM
@cappaj makes a good point. If you are trying to set up the referral AFTER you have already activated an account, then you need moderator help to add the referral number
GC
08-07-2018 07:44 PM
Are you activating your account as you set it up? Or was it already activated in store? I don't know what the process is for creating your online account after activating in store, but I wonder if your time to input the referrer was in store, and not while setting up your self serve account.
08-07-2018 07:39 PM
This is the first time I heard of problems with adding a referral during activation. The biggest issues are with adding a credit card and porting. Using an up to date browser, clearing cache, incognito mode should help. @jeff1965, if your still have a bad referral, I would be more than willing to offer my number. Just kidding. ![]()
08-07-2018 07:38 PM
Are you saying that you cannot type the number in the box? If so, make sure you choose the option to the left that says "Yes, I was referred" or something like that.
GC
08-07-2018 07:23 PM
it didnt matter if I used safari, Internet explorer, or chrome. It wouldnt allow me to set up the account inputting the refer phone # in
08-07-2018 07:09 PM
08-07-2018 07:06 PM
1. What browser are you using?
Chrome brawser works
2. If you are using Chrome, clear the cache and restart browser and start over again.
Good luck
08-07-2018 07:06 PM
Enter your friend's Public Mobile 10 digit number with no spaces or dashes, just the numbers . It should work fine. Have not heard of this not working before.
GC
