03-04-2024 08:34 PM
Hi, There:
I opened up an account with public mobile couple days ago. Although I was able to make outbound calls using my existing number ever since I transferred it from my previous provider, I found out that I cannot receive any inbound calls, neither any text messages. Anyone has any ideas?
03-04-2024 08:48 PM
Have done that. Will wait for their responses. Thanks again!
03-04-2024 08:48 PM
Sounds like the port was not successful. Is your old provider's number still active? Did you reply to the text within the 90 minutes window?
There is a phone number to call to verify. I will send you another message with the number to call.
03-04-2024 08:47 PM
@RubyGuo8 - If so, then contact CS_Agent here:
⬇️ Click the link for an Agent * ⬇️
* - CS_Agent will typically get back to you within 48 hours. You will be required to login to your Public Mobile Community Account to contact CS_Agent. Once you are finished making the ticket with CS_Agent, please ensure that you monitor for an agent because they may notify you asking for some information via Private Message, in your mailbox by clicking this link here: Messages
03-04-2024 08:46 PM
Thanks @fixin. However the previous sim is no longer working.
03-04-2024 08:39 PM
