Issue with Phone.
09-15-2022 07:15 PM - edited 09-15-2022 10:18 PM
09-19-2022 12:15 AM
09-15-2022 07:46 PM
09-15-2022 07:20 PM
@Kishnabe hi first try manualy setting your network to 3g this should help with your calls
to find out why you are having these problems
you need the help of a service rep since you are having issues with simon
private message them here
https://productioncommunity.publicmobile.ca/t5/notes/composepage/note-to-user
09-15-2022 07:18 PM
HI @Kishnabe
did you try reboot your phone?
or try to reseat the sim card?
Try your sim card in another phone as well if possible.
to open ticket, you can also message them instead of going through Chatbot:
