10-14-2019 01:10 PM - edited 01-05-2022 09:28 AM
Hi there !
I'm using Autopay with $40 plan and with $2 reward,
the due amount should be 38 + tax but after first two months it started charging me $42.94
What's wrong here ?
10-14-2019 04:15 PM - edited 10-14-2019 04:16 PM
10-14-2019 02:14 PM - edited 10-14-2019 04:10 PM
@RossN wrote:@harshpanchal that amount seems correct to me
no need for a moderator
@harshpanchal @RossN is indeed correct. $38×.13%=$42.94. When you activated you paid $40 +tax. Your renewal would have charged you $40-$4 autopay for your first 30 *and second 30 day plans. So $36+13% tax =$40.68 Your third renewal and following renewals will be $42.94 unless you change your plan.
*autopay rewards are credited towards your first renewal
10-14-2019 01:39 PM - edited 10-14-2019 01:40 PM
10-14-2019 01:34 PM
You should get in touch with a moderator who can look into this issue for you. Click on circled question mark? to find out how. I think it will be resolved.
10-14-2019 01:17 PM
38*1.13 = $42.94
10-14-2019 01:16 PM
It's possibly just tax. What is the tax rate in your province?
