a week ago - last edited a week ago
Whenever i Screen a Phone Call it says caller is leaving a message but then that message doesn't show up till the next day or half a day later. additionally my phone also says it has 5 voice mails but when i check it says no new messages.
a week ago
thank you this solved my problem.
a week ago
Is your phone set to the correct time and time zone?
a week ago
hi @Mr_Lizard
are you using iPhone with Live Voicemail enabled? disable it and it should resolve the issue
