08-05-2020 08:10 PM - edited 01-05-2022 12:24 PM
Hello all,
I was thinking about switching over to PM from Freedom mobile due to coverage issues where I am located and just wanted to know if the S9 will work with the PM sim cards
08-05-2020 09:42 PM - edited 08-05-2020 09:52 PM
I've been using an s7 with no issues, should be all good
Oh! While I'm thinking of it though, I remember being concerned about inserting the new sim card the first time, because the first sim card it ever used (my case koodo) it did a factory reset on me. It's supposed to be some sort of safety feature or something in the Samsung models? But I made a full backup just in case... Didn't end up needing it, but better safe than sorry right ? I've read it should only be a thing with the very first sim card, but I still wanted to be safe.
Just as a heads up 🙂
08-05-2020 08:28 PM - edited 08-05-2020 08:29 PM
08-05-2020 08:23 PM
@Jesse250 My wife uses the S9+ here and it seems to work great so far.
08-05-2020 08:19 PM
You guys are on it in here! Thanks for the help folks
08-05-2020 08:18 PM
08-05-2020 08:16 PM
oh right on I couldn't pull up that page, it wouldn't load for me for some reason. Thank you
08-05-2020 08:16 PM
@Jesse250 Yes, it is supported! Don't worry and go for it!
08-05-2020 08:16 PM
@Jesse250 according to this site https://apn-canada.gishan.net/en/apn/public-mobile/samsung-galaxy-s9 its 100% compatible has both the required 3g and 4g LTE bands. Make sure its unlocked. Welcome to PM. Stay safe.
Here's 4 articles on activation and porting and the Refer a friend reward if you need them:
1. What you require to activate https://www.publicmobile.ca/en/bc/get-help/articles/what-you-need-to-activate
2.How to activate https://www.publicmobile.ca/en/bc/get-help/articles/activation-account-set-up
3.How to port https://www.publicmobile.ca/en/bc/get-help/articles/choose-your-phone-number
4. Refer a friend https://www.publicmobile.ca/en/on/get-help/articles/the-refer-a-friend-reward
08-05-2020 08:13 PM
