06-09-2019 01:28 AM - edited 01-05-2022 05:17 AM
Hi, I have a Samsung Galaxy Nexus (i9250-M).
According to the link below it's a GSM/HSPA phone.
https://www.gsmarena.com/samsung_galaxy_nexus_i9250m-4432.php#
When i do a phone check (link below) on Public Mobile I get a green checkmark on 3G 850MHz, 1900MHz.
And an orange exclamation point warning for 4G.
https://www.publicmobile.ca/en/bc/get-started
Will my phone work on talk and data?
Or just talk?
Or not at all?
It's not very clear even with the phone checker.
thanks for any help
06-09-2019 01:38 PM
@phoneish you're right. It'll be same as Virgin. There's no requirement to have 4G for data. You'll be fine.
06-09-2019 01:38 PM
Since PM has coverage very similar to Virgin (Bell), in my opinion, it is safe to assume data coverage wouldnt be any worse.
06-09-2019 01:30 PM
thanks.
Assuming I'm not getting LTE data right now with Virgin Mobile (because my phone won't handle LTE). Would I be safe to assume the data coverage shouldn't be any worse than what I have with Virgin Mobile?
06-09-2019 01:31 AM
@phoneish wrote:Hi, I have a Samsung Galaxy Nexus (i9250-M).
Or just talk?
Or not at all?
thanks for any help
It means it'll work fine for voice but not LTE data. iirc it'll work for HSDPA data.
06-09-2019 01:30 AM
@phoneishTalk and HSPDA data would work.. you just won't get LTE data.. so that means your data coverage might be spotty depending where you are.
