10-20-2017 08:21 PM - edited 01-04-2022 02:47 PM
Before start to use PM just wondering if my Iphone 7 Plus is compatible with this network. Check IMEI on site. It says " Your device will not work on our Network"
10-21-2017 11:55 AM
No issues, will work fine.
Model A1778* / Model A1784*
FDD-LTE (Bands 1, 2, 3, 4, 5, 7, 8, 12, 13, 17, 18, 19, 20, 25, 26, 27, 28, 29, 30)
TD-LTE (Bands 38, 39, 40, 41)
UMTS/HSPA+/DC-HSDPA (850, 900, 1700/2100, 1900, 2100 MHz)
GSM/EDGE (850, 900, 1800, 1900 MHz)
Models A1778 and A1784 do not support CDMA networks, such as those used by Verizon and Sprint.
10-20-2017 09:17 PM
Model A 1784
I checked that site, it tell me should should work in 3G and 4G LTE.
10-20-2017 09:04 PM
@NVM, was your phone unlocked when you got it or what provider did you come from? Do you know if is an Asian variant? I suggest you try the site I listed, it asks for make and model and what network you are on.
10-20-2017 08:54 PM - edited 10-20-2017 09:09 PM
Below says " Your device has not been reported as lost or stolen"
I ordered this phone from Apple. Should be unlocked
10-20-2017 08:43 PM
@NVM, that is strange as the IMEI checker is really only checking to see if the phone is blacklisted. Have you reported this phone lost or stolen? Phones that are locked to Telus, Koodo will work as well as unlockd phones if they have the correct bands. www.willmyphonework.net is a great site to see if your phone will work.
