01-25-2018 05:57 PM - edited 01-04-2022 03:23 PM
I am ordering a phone from china and i searched on different frequency websites and saw taht there might be a chance that public mobiles bands are the same as on the phone.
The phone is the elephone s8 and i just want to double check before ordering a sim that i will be alright
thank you
01-26-2018 05:08 AM
Had a friend who bought that exact phone. It wouldn't work on either Telus or Bell networks.
01-25-2018 07:22 PM
Here is a list of frequencies that are able to be used hopefully this helps:
Frequency range Band number Protocol Class Status Note(s)
| 850 MHz CLR | 5 | UMTS/HSDPA/HSPA+/DC-HSPA+ | 3G/"4G" | Active | Fallback for calls. |
| 1,900 MHz PCS | 2 | UMTS/HSDPA/HSPA+/DC-HSPA+ | 3G/"4G" | Active | Fallback for calls. |
| 850 MHz CLR | 5 | LTE | 4G | Active / Being deployed | Used for extra bandwidth within cities and rural coverage. Only seen in British Columbia.[21] |
| 1,900 MHz PCS | 2 | LTE / LTE Advanced | 4G | Active / Being deployed | Secondary LTE Band being deployed and used for LTE / LTE Advanced coverage. |
| 700 MHz A/B/C/E | 12/13/17/29 | LTE / LTE Advanced | 4G | Active / Being deployed | Mainly used in rural areas / rural coverage. |
| 1,700/2,100 MHz AWS | 4 | LTE / LTE Advanced | 4G | Active | Main LTE Band used across the country. Also being used to provide LTE Advanced coverage. |
| 2,600 MHz IMT-E | 7 | LTE / LTE Advanced | 4G | Active / Being deployed | Found in select markets, but being developed slowly in new markets alongside to provide LTE Advancedcoverage. |
01-25-2018 07:11 PM
@koimr1, @ckl your analysis is correct. @jacobyo that phone is not compatible with Public Mobile. The only provider you will be able to use it with in Canada is Rogers or Fido, since rogers is the only Canadian network operator to offer 2G GSM services, and the 3G bands on the phone you want to buy are not compatible with any Canadian provider.
01-25-2018 06:37 PM
I'm looking here: Elephone S8
If I'm reading this properly (and @ckl posted the same bands I see) then you won't be able to make/receive calls and you only get LTE on band 7 only which is only available in certain areas and is such high frequency that building penetration is gonna be an issue.
Specs are nice but I think I'd stay away until someone else gets this one and confirms it works with Telus/Koodo/PM first.
01-25-2018 06:27 PM - edited 01-25-2018 06:35 PM
The specs for your phone from the official website is:
GSM:B2/B3/B5/B8 (1900/1800/850/900)
WCDMA:B1/B8 (2100/900)
FDD-LTE:B1/B3/B7/B20 (2100/1800/2600/800)
TDD-LTE:B38/B40(2600/2300)
Public mobile mainly uses these bands:
3G use (UMTS/WCDMA/HSPA): 850MHz/1900MHz bands
4G/LTE use: 700/1700/2100/2600Mhz bands
So it appears that your S8 will have very limited connectivity if at all. Public Mobile is 3G and above, so no GSM.
willmyphonework.net doesn't list the S8, but has the S7. If they have similar frequencies, then connectivity is limited.
You can read a review of it here. Scroll down to the phone calls section and you will see it is not really compatible with North American frequencies:
https://www.androidheadlines.com/2017/09/elephone-s8-review-blending-low-cost-with-great-design.html
01-25-2018 06:12 PM
The frequencies supported by PM can be found here: https://en.m.wikipedia.org/wiki/Telus_Mobility
