08-23-2015 09:13 AM - edited 01-04-2022 12:43 PM
So I'm usually pretty tech savvy however my brain has failed me lol, I stumbled across this phone which and I'm not sure if it will work with our Network, so here is it's bands:
Brand:
2G: GSM 850/900/1800/1900MHz
3G: WCDMA 900/1900/2100MHz
4G: FDD-LTE B1/B3/B7/B20
Hopefully one of you super tech mayors can answer this question for me 🙂
08-23-2015 12:52 PM
Hello,
Martin I agree with you. I just edited my post regarding service and coverage.
It's important to let them know if the phone is fully compatible or not.
08-23-2015 12:03 PM
08-23-2015 11:47 AM - edited 08-23-2015 12:49 PM
Hello,
If the phone is missing one of the frequencies it does not mean it will not work, It can still work as far as long as there is at least one frequency that both phone and network support
**please note that many networks work on 2 or more frequencies, typically a high and a low ones. If a phone can use one of the frequencies and not the other, you will get service, but coverage and/or signal strength may be reduced.
08-23-2015 11:26 AM
08-23-2015 11:25 AM
08-23-2015 11:23 AM
08-23-2015 11:13 AM
Thanks Martin.
08-23-2015 11:08 AM
08-23-2015 10:58 AM
Perhaps @Martin can have a look to confirm, but I believe
Kristine's 3G: WCDMA 900/1900/2100MHz is not the same as
PM's 3G UMTS/HSDPA = (850MHz / 1900MHz) aka Bands 5/2
So her her conclusion seems correct to me.
08-23-2015 10:26 AM
Well, Perhaps Telus should expand their Band Frequencies a bit more, so that maybe a few more Handset varieties can be rendered compatible. This way, Reducing the # of Incompatible handsets from that list even further, To a Certain degree
08-23-2015 10:16 AM
This website is amazing thank you, and it does not work if anyone else is ever wondering, however it works on other other 2 big ones Rogers and Bell but I will not ever be changing over to them lol
08-23-2015 10:13 AM
Can you please provide us with the phone and its model your are to get, so we can be able to determine whether it will work or not.
Regarding the 2G and 3G freqs on this phone it will work with PM, but when it comes to 4G LTE the phone support 2100/1800/2600/800. That doesn't match the frequency PM provide. So I will suggest you try to use
http://www.willmyphonework.net/ and check if this phone is compatible or not.
08-23-2015 10:07 AM - edited 08-23-2015 10:08 AM
You could also check here http://www.willmyphonework.net Also recommended by @Martin
08-23-2015 10:05 AM
Not a Mayor but the following is mashed together from posts by @Cyber and @Martin
Telus/Koodo/Public Mobile frequency are :
4G LTE Band 4 = (2100MHz / 1700MHz) aka paired together Band 4
4G LTE-Advanced = 700MHz (LTE-A apparently justt launched by Telus/Bell) aka Band 17
