09-29-2019 12:27 PM - edited 01-05-2022 07:20 AM
09-29-2019 05:16 PM
Thankyou
09-29-2019 05:16 PM
Thank you for your help
09-29-2019 03:55 PM
@Gman99 Check this info to ensure a happy result: https://productioncommunity.publicmobile.ca/t5/Phones-Hardware/FYI-iOS-and-APNs/m-p/323119/highlight...
and if you're a pessimist; https://productioncommunity.publicmobile.ca/t5/Getting-Started/BE-PREPARED/m-p/112014#M20827
NO need to have it unlocked, but does improve your flexibility to get best deal anywhere.
09-29-2019 01:24 PM
Yes, if it works on Telus then it should be compatible with PM. PM uses the same cell towers as Telus and Bell.
09-29-2019 12:29 PM
Yes! It uses the same network as Telus, so any mobile currently on Telus network will work with Public Mobile 🙂
