11-14-2021 12:23 PM - edited 01-04-2022 05:12 AM
I have a wifi plus data capable iPad, original data plan, its own phone number, its own SIM, not renewed through telus, way too expensive. Can i set iPad up with Public Mobility’s SIM card on its own separate data plan?
Service
11-17-2021 11:10 AM
How much data is used after using Wifi on iPad?
If it is always used by you while off Wifi then you can use tethering, else taking the minimum PM plan and adding required data every now n then as the add-ons dont expire until they run out.
11-14-2021 12:42 PM
@Sjm58...PM isn't really designed with any data only plans. You could just upgrade your current PM plan to the amount of data you want...then tether your ipad with hotspot feature.
Would that work for you ?
11-14-2021 12:37 PM
at public mobile not have separate data plan,
the have call /Text /data.
you can review 6 Plans (publicmobile.ca)
11-14-2021 12:25 PM
You can set it up with data but PM no longer offers a data only plan.
11-14-2021 12:25 PM - edited 11-14-2021 12:26 PM
Yes, but there is no data only plan. You would have to buy the $15 plan or more and buy add on data.
