11-23-2016 04:22 PM - edited 01-05-2022 12:52 AM
My wife can't send a text through her Ipad, she just gets a "Not Delivered" message after a few minuets.
Anyone have any suggestions.......
10-06-2018 06:35 AM
The reason behind not sending text msg in iPad is due to setting issue. Make sure your iMessage is working or not, if it is working then try some few different solution.First of all make sure "send as sms" is enabled in settings then go to message option.
if still anyone getting issue then i recommend you to read iPad Mini Won't Turn On blog to get more information.
11-23-2016 08:00 PM
All is well in my home, thanks for your solution...
11-23-2016 05:57 PM
Thanks for the reply, will give it a try, and let you know....
11-23-2016 04:45 PM
On her iPhone try turning off text message forwarding and turning it back on again?
