Invalid sim message
05-10-2019 11:15 AM - edited 01-05-2022 04:51 AM
Hi,
I bought a new Sim card yesterday and I'm trying to activate it through the website. However, just after typing my simcard number I'm getting an error message "Invalid sim number". Tried with Chrome, IE, Firefox and Edge, incognito mode, cleaning cookies, restart and all basic troubleshooting. Also wrote a message to Moderator, but no answer so far.
Can anyone help me?
Thanks
Joining Public
05-10-2019 12:43 PM
@polaken wrote:Finally went to the store and changed the sim card. Thanks for the answers.
This thread can be closed.
See that black box saying Accept as solution? You can click that on the post with that answer.
05-10-2019 12:43 PM
05-10-2019 12:40 PM
05-10-2019 11:37 AM - edited 05-10-2019 11:38 AM
@polaken wrote:Hi,
Can anyone help me?
Thanks
@polaken Where did you buy the sim from? Was it a new sim card?. If you get an invalid sim card error as soon as you put in the S# then there are three possible scenarios:
- Sim has been previously activated and account cancelled
- There was an issue during your activation session and you account got locked
- The sim card is defective or you are not entering the sim number correctly
In the first case you need a new sim. If number 2 occured then you need to wait an hour and try the activation again. To eliminate number three check the sim number and use the one printed on the card.
05-10-2019 11:27 AM
Looks like that you already tried most of the basic troubleshooting suggestions.
One possibility is that your SIM card is indeed invalid. You might need to return to store to get the SIM card replaced with another one.
Moderators will take up to 48 hours to respond.
