Invalid numbers?
Bob19
I am trying to dial 613 310-xxxx but Public mobile says it's an invalid number, check it and try again.
2 REPLIES 2
NDesai
@Bob19 If you know that number belongs to someone for sure, try dialling by adding 1 or +1 in front of it. If it was a missed call from that number and no voicemail, there is no point of calling back in case of spam as mentioned above.
dust2dust
Are you trying to call back a junk call? I get the same result (with my number hidden).
