Invalid Sim
pduvnjak
I am trying to activate a Sim card which I just purchased at Walmart and I keep getting an invalid Sim message any help would be appreciated. @CS_Agent
pduvnjak
I was able fix the problem with help from support.
Jackhyf63
@pduvnjak
If it says invalid then the sim may be used before. Are you sure it's a brand new sim?
rligsay
I was getting that error too initially.
I ended up closing my browser and trying again. That seemed to have worked for me and I was able to activate my sim.
pduvnjak
Thank you
Lieux
And you will need to wait 24 to 48 hours to get an answer @pduvnjak be patient they will help you.
ShawnC13
You will need to contact the Moderators via private message to have them look into this for you.
To send a private message to a moderator click this link and describe your issue.
Community Moderators are available from Monday-Friday 9am(Eastern) to 9pm(Eastern) and Saturday, and Sunday from 9am(Eastern) to 7:30pm(Eastern) More info on moderators
