Intl long distance
missorange
400 min Intl Long Distance (Incl Canada & US)  if this add on can call local?
It can only be used for that if your plan already has talk/calling including. It cannot be used to add calling minutes to a data-only plan.
Forrest
just make sure that if you need the international calling "add on" that the country you want to call is on the list
hairbag1
Better option is the $5 for 500 minutes of Canada wide calling add-on. They don't expire either until you use them up. Great addition to a limited minutes calling plan.
hairbag1
Yep...if your $10 or $15 plan runs out of calling minutes, the add-on will take over for local calls as well.
