Internet
John092
Did not have issue using their internet downtown Torotno yesterday? My internet was not loading my YouTube or fb etc. only my iMessage was working.if you had the same issue how did you fix it ?
NorthernLights
i have an older phone and have to power down to get it to work
John092
Thank you guys I am reading ppl having this issue when they updated their iPhone to 18.1.1, I restarted my phone hopes that fix the problem
@John092
If you are referring to your data. Reset your Network settings.
If you are referring to your home internet than it is your home internet provider that is the issue. Try unplugging the modem or router for 30 seconds and plug it back on.
hairbag1
@John092
I'm not in Toronto, but I do know that there can be localized network upsets that will cause symptoms as you mention. It might be just fine today. You could try rebooting your cell to see if that helps. I don't see anyone else reporting similar issue in Toronto...but it's early !
