04-25-2023 08:00 PM
Hi
I am travelling to Jordan. Can I purchase a roaming add on in that country?
04-26-2023 12:47 AM
@sam23571 If you are looking to get Data Roaming and have eSIM compatible phone, check out Airalo.com They provide pretty cheap data roaming services across many countries. For calling and texting, stick with WhatsApp or Fongo.
04-25-2023 09:14 PM
Wellllll...maybe from somewhere..but not here. To technically answer your question. 🙂
04-25-2023 08:01 PM - edited 04-25-2023 08:03 PM
No you can’t. PM only offer Roaming while you are in the USA.
You can use WhatsApp or TextNow for free WiFi calling and texting or purchase a local SIM.
04-25-2023 08:01 PM
@sam23571 sorry, no roaming in Jordan,
PM has only roaming in USA.
You will have to rely on local prepaid data sim card, and use VoIP app TextNow to make free calls back to Canada
