International roaming
05-30-2019 11:44 AM - edited 01-05-2022 05:08 AM
I need international roaming. Are there still ways to move to Telus or koodoo?
Joining Public
05-30-2019 12:07 PM
05-30-2019 11:53 AM
@shemspi wrote:I need international roaming. Are there still ways to move to Telus or koodoo?
Unfortunately PM only has an option for roaming to USA. If your travels take you to other places, your options are limited. You can consider a free voip app like TextNow to use abroad. You'll be able to call Canada or USA for free as long as you have a robust wifi signal.
You can buy a sim card in the country you happen to be in. They seem to be the preferred method for travellers now.
Good luck wherever you go.
05-30-2019 11:46 AM - edited 05-30-2019 11:48 AM
You can switch to Telus or Koodoo at anytime, port your number over to them.
Your other option would be to get a SIM for the country you are travelling. Once there, purchase one.
There are also lots of options for SMS forwarding, using wifi for things like Fongo, what's app, etc.
