International Texting on my plan
11-23-2017 06:29 AM - edited 01-04-2022 02:59 PM
Didn’t fully understand the correct answer when I searched.. I have a Canadian plan which is call province wide... international texting and Data
- I am going to the US for 3 months, will I be able to send text to Canadian numbers from the US when I am there at no charge if I don’t take any add on or do I have to add on a roaming plan of any kind ??
Suzie Beauparlant
11-23-2017 07:28 AM
@Suzie1If going for 3 months might I suggest Roam Mobility. They are a Canadian company who can offer plans for snowbsnowbirds. You get an American number and they use T-Mobile. They can be found at www.roammobility.com
11-23-2017 07:10 AM - edited 11-23-2017 07:13 AM
All the features of your plan allow you to use your phone while in Canada. In order to use your phone while in the US, you will need a US Add-on so you can use your device on our partner networks (AT&T and T-Mobile).
Through self-serve you can select the add-on that will meet you needs. Please know the process of adding and add-on is a two step process of adding funds to your account and then going back and purchasing the add-on. They are all 10-day add-ons, day 1 being the day you buy and day 10 ending at midnight EST.
For a 3 month stay, you will likely be better off getting a SIM card and account in the US for that time as the cost of add-ons will add up fast. This process I listed above will at least buy you some time when you get down there.
