International Text Agreements
cellphonesaver
Hi all! Can anyone point me to Telus international texting carrier list agreements? It used to be on their site but can't find it anymore.
It seems that for one carrier I sent text it's only working one way (they get my text from PM, but can't respond back).
Thanks!
7 REPLIES 7
cellphonesaver
It's still hit and miss for me. Some people can respond, some can't. Strange. And one message came as 011 and then everything else after it
cellphonesaver
You misunderstood a bit : they are able to receive  but couldn't respond back. Texts in Belarus is free for incoming  and for any outgoing text cost is very minimal  The destination doesn't matter too.
I agree messengers area more secure and reliable  but again the problem is that some people have WhatsApp  others are Viber etc. Some people don't use them and just use texts .
Anyways, I've left feedback on Telus site and magically received text from my friend from Life Belarus.
Most likely it's a matter of business request to allow messages back from Telus side
drmartin
@cellphonesaver wrote:
Thanks, unfortunately this is not helpful 😞
Sometimes text is the fastest way to reach some people
No it's not helpful... but texts lacks security and reliability in general.  The worldwide implementation of SMS all depends on each carrier and it can be that the carrier in Belarus just doesn't like the free texts coming from Canada, since many countries in the world charge an arm-and-a-leg for texts.
As a suggestion, Signal, WhatsApp or Viber are excellent complimentary tools to texting.  When you use Signal on an Android phone it can replace the provided Android texting app and works seamlessly with it - detecting if your contact is also using Signal and immediately sending free encrypted text messages through internet.  When a contact doesn't have Signal installed it sends the message as a standard SMS instead.  No signup or special usernames needed (although it does need to send you an SMS to confirm you control the phone number you register).
cellphonesaver
cellphonesaver
Life(BeST) carrier in Belarus
will13am
This is the link in the Telus site about international text.  There is no discussion of agreements.  I get similar issues texting to/from UK.  My solution is to avoid using text which is archaic and should not have survived this long.  Messaging apps which use data are so much more reliable.
https://www.telus.com/en/bc/support/article/text-messages-international
KMG
Which carrier are you having a problem with?
