International Minutes
izthebye2
My international minutes have almost been used up. I have made no international calls. Local calls show 1 minute. Where did my international minutes go???
Coka
@JL9 wrote:
You can buy a decent chunk of mins as an add on for a pretty good price if you want a cushion
Yes. 1 cent = 1 minute. Very good backup.
JL9
It's looking like you are on the $15 plan then and the reason is as stated above. You can buy a decent chunk of mins as an add on for a pretty good price if you want a cushion
HALIMACS
Just to be certain, @izthebye2, the minutes show under your "my data and add-ons" section as minutes used / total minutes available:
Just confirming you're aware of this; I think you likely are.
Meow
What Plan do you have?
If you are on $15 plan, after using 100 outgoing minutes any other add-on (bonus or paid) for long distance will be used.
Can you provide screenshot of your add-on usage?
These minutes from the holiday giveaway can also be used for domestic calls. At some point, you may have ran out of domestic calling minutes and the add-on minutes were then used.
