09-07-2022 08:28 AM
I have an international long distance plan I am in Newfoundland trying to call St. Pierre which is France and I am unable to call any advice
09-07-2022 11:10 AM - edited 09-07-2022 11:56 AM
1. Texting should work.
2. If you used the zoiper app over wifi or data with a voip.ms account you should be able to call. And you can program the caller ID to be your PM number. You don't need a DID number so you balance will only decline for the out bound calls that you make.
Edit:
3. Voip.ms is expensive at 28 cents a minute.
4. FaceTime audio should work too.
09-07-2022 09:06 AM
Here is old thread about the same issue:
https://productioncommunity.publicmobile.ca/t5/Get-Support/St-Pierre-and-miquelon/m-p/465303#M337423
Unfortunately, PM adds ons do not cover this location.
09-07-2022 08:43 AM
@glenhorton hi do you mean Saint Pierre and Miquelon ? if so it may be tehnically part of france but it won't be included in the long distance minutes
