International Long Distance Minutes
Sai7
Hello,
I accidentally bought an add-on of 300 International Long Distance Minutes and I did not know that the list of countries on international calls is limited!
Could you refund the $15 to be able to buy a correct add-on. Thanks
Meow
Ask agent for assistance. They might be sympathetic and apply credit on your account.
Usually add-on purchases are not refundable.
You are talking to customers like yourself. Agents do NOT monitor nor accept requests through this forum.
To Contact CSA-agent: https://www.publicmobile.ca/en/on/get-help/articles/contact-an-agent
Ticket has to be opened through chatbot - https://widget.telus.tiia.ai/publicmobile/publicmobile.html
Just type ‘ticket’ and follow prompts. Having a ticket is preferred way to contact agent as they might respond faster then receiving personal mail.
If opening a ticket does not work very first time, contact agent directly: send a private message to the CSA - agent by clicking (Ctrl+) Here
Agent’s response is usually between 15 and 120 minutes with a ticket. Private messaging might take longer.
Watch for envelope in top right corner of Community page. It will show Number of unread emails.
dust2dust
While refunds or credits are not generally granted, you can try your luck with support.
@Sai7  Please submit ticket with support and see if they can reverse this for you
private message   To CS_Agents click
