08-20-2017 01:24 AM - edited 01-04-2022 02:32 PM
I was wondering how much it costs per minute for international calling if I did not buy any add on? For example if I called from Canada to China, how much would it cost per minute? If it matters, both phone numbers were 416 numbers.
Thank you.
08-20-2017 08:39 PM
Try WeChat
08-20-2017 02:05 PM
08-20-2017 01:23 PM
@will13am Good to know, thank you for that information.
08-20-2017 09:40 AM
I should clarify one thing, the 400 minute add-on includes international calling, the 200 minute add-on does not. It's only Canada and US minutes.
08-20-2017 07:55 AM - edited 08-20-2017 08:18 AM
08-20-2017 02:35 AM - edited 08-20-2017 02:37 AM
Public Mobile doesn't have pay-per-use services, so you would need to purchase a Long Distance Add-on to cover any calls to China or other countries outside of Canada.
You can purchase 200 minutes for $8 or 400 minutes for $15 through your self-serve account. Any unused minutes will roll over to your next cycle, so if you're only making occasional or short length calls these add-ons could last you a while.
In terms of how the long distance works -- if you call a person with a 416 area code number who is physically in China, you will not be charged long distance. However, they would most likely be charged roaming or long distance fees depending on the carrier.
08-20-2017 01:48 AM - edited 08-20-2017 01:49 AM
Yes calling the same area code as you are in, is a free local call. You can try it out.
08-20-2017 01:36 AM
08-20-2017 01:33 AM
if you want to call an international number, I believe you will need to buy an international calling add on.
But if you are simply calling from a 416 number to another 416 number that is considered a local call and you should be able to call without any add ons.
