05-20-2023 07:54 PM
Hello I am switching providers to public mobile and during the transfer an error occurred with typing in my IMEI number wrong as PM is saying that they tried porting and failed. Do I need to call assistance to have them re-port the number?
Thank you for your time
05-21-2023 08:42 AM
Did it end up working for you?
05-20-2023 07:56 PM
@rrbudd It is better to provide the account number of the old provider to avoid problem with Porting
And no worry, there is a number to call to talk to live support. You can call them and provide them the correct IMEI or account number, they can re-trigger the process for you. I will message the number to you via the Community inbox ( https://productioncommunity.publicmobile.ca/t5/notes/privatenotespage ) . Check the envelope icon on top right. Call them and get it fixed
05-20-2023 07:55 PM
@rrbudd wrote:Hello I am switching providers to public mobile and during the transfer an error occurred with typing in my IMEI number wrong as PM is saying that they tried porting and failed. Do I need to call assistance to have them re-port the number?
A ticket needs to be opened using the chatbot at https://widget.telus.tiia.ai/publicmobile/publicmobile.html. If possible, use account number instead of IMEI.
