05-21-2023 12:09 AM
Add on not working. Purchased US roaming for 15 days, hasn’t worked a day and want a refund. You can see in my account it is all 0’s for usage. Refund please and not happy with the service.
05-21-2023 08:39 AM
@Ella09 - restarting your phone or performing a reset of the device's network settings can sometimes help you connect to the proper network whilst travelling in the USA if you have the proper Roaming Addon purchased. Note though, there are area in the USA that will have issues.
Perform a Reset of your device's Network Settings. This also resets Wi-Fi networks and passwords, cellular settings, VPN and APN settings, and connected Bluetooth devices that you've used before.
Iphone:
To Reset Network Settings, begin by opening the Settings app. Next, tap General -> Transfer or Reset iPhone -> Reset -> Reset Network Settings. and enter your passcode.
Your iPhone will reset network settings and restart itself.
android:
Find and tap Settings > System > Advanced > Reset options > Reset network settings.
To add to @DDM69 post, if you are still having issues, than you may inquire about a credit to your account with Public representatives/CSA.
Public Mobile Representatives customer support agents (CSA) can be contacted by either two methods, found here:
05-21-2023 02:12 AM
05-21-2023 12:33 AM - edited 05-21-2023 12:42 AM
@Ella09 are you still in US now? which city and state you are at?
Before you give up, couple things to check.
First, is your phone connecting to T-Mobile network? If not, try to change the Network connection from Automatic to Manual and manually connect to T-Mobile
Also, make sure you have enabled Mobile data roaming on your phone
Let us know how it turns out
05-21-2023 12:11 AM - edited 05-21-2023 12:13 AM
You are posting to a forum of all customers. We cannot rebate anything. You’ll need to submit a ticket to request a refund.
