Incorrect IMEI during activation
akeele289
Hello I input an incorrect IMEI during activation and the link sent to rectify is not working. Can anyone help me?
Jdodge508
Could you pm me that phone number as well, please? Having the same issue tryin to activate eSIM and port my number
akeele289
Thank you, will call now!
HI @akeele289   You can call a porting support team to give them the correct IMEI.  But would be better and quicker if you can provide them the account number
I am messaging you the phone number.  Please check your Community inbox
LitlLdy
@akeele289 , if you’re trying to port you phone number to Public Mobile it works better using your account # from the provider your porting your phone # from!
Edit: I’m a slow typer. @softech provided better information 😉
@akeele289
so, you have activated the plan and your PM sim can make outgoing calls? just not incoming as porting is an issue?
Yes, using Account number is better than IMEI
There is a number to call to talk to live support,  You can provide them the correct information and they can re-trigger the process for you.  I will message the number to you via the Community inbox ( https://productioncommunity.publicmobile.ca/t5/notes/privatenotespage ) .  Check the envelope icon on top right.  Call them and get it fixed
pmva
@akeele289 Are you referring to entering the wrong IMEI during porting to a number to PM?  You can enter it again from your account under Profile if you want to attempt the port again.
