Incorrect ESN/MEID text message
GI1231
Hello, I initiated the transfer number process a couple hours ago, and I got a text right away from Public Mobile with the wrong ESN etc message. No one contacted me. Please advise how this can be resolved.
1 REPLY 1
@GI1231
It is better (and safer) to use account number of your old provider instead of IMEI/ESN
There is a number to call to talk to live support and you can update them with the account number.  They can re-trigger the process for you.  I will message the number to you via the Community inbox ( https://productioncommunity.publicmobile.ca/t5/notes/privatenotespage ) .  Check the envelope icon on top right.  Call them and get it fixed
