Incorrect ESN/MEID message when porting number
SteveDave
I am porting to Public Mobile for another carrier. I entered the requested info and all appeared to be ok then I got the msg. I will like to know how to update the ESN MEID to resolve this.
2 REPLIES 2
@SteveDave
it is safer to provide account number than IMEI
No worry.  There is a number to call to talk to live support,  they can re-trigger the process for you.  I will message the number to you via the Community inbox ( https://productioncommunity.publicmobile.ca/t5/notes/privatenotespage ) .  Check the envelope icon on top right.  Call them and get it fixed
@SteveDave  Please message support
message support directly
while your already here and logged in the community you can send a private message   To CS_Agents click
