Incomplete Number Port – Unable to Receive Incoming Calls
Kapil331
  • My number port from Fido is incomplete. I can make outgoing calls but cannot receive incoming calls. Please complete or re-push the port.
2 REPLIES 2
richlam83
I have the same issue.  Wondering if you can also send me the phone number to call to re-trigger the process.
Thanks!
@Kapil331
A critical part to porting is to receive a text from your old provider and you have to reply YES within 90 mins.  If you are not receiving calls and text on your PM sim card, and only outgoing calls work, then you might have missed the step and hence porting was not completed
There is a number to call to talk to live support,  they can re-trigger the process for you.  I will message the number to you via the Community inbox ( https://productioncommunity.publicmobile.ca/t5/notes/privatenotespage ) .  Check the envelope icon on top right.  Call them and get it fixed
But if you are unable to reach someone from the live support with the phone number I sent you, you can also message them here:
**After opening the ticket, please monitor your community inbox (envelope icon on the top right), the customer support agent will get back to you in sending a message there.
