Incoming calls
KJM
So on the 27 of dec I started my public account and transferred my number from chatr but now I can only receive calls or text from the area code that I’m in on from any other area code?
I’ve tried resetting the network settings but didn’t do anything.
Anyone that calls from other area code’s says it just goes to straight to voicemail.
@KJM   so, you only receive some incoming calls but not all?
For those who cannot reach you, did it go to your PM voice mail? or they heard other recording?  can you confirm from your friends who cannot reach you?
If they get to your PM voicemail , it could be a reception issue.  try to change your phone Network setting  to 3G Only and see if it helps
@KJM
Did you leave the OLD provider SIM card in your phone to accept the PORT via SMS/text ?
If not, than the port likely did not complete, and it may be stuck.
Submit a ticket by methods provided by @HALIMACS , OR call the Porting Phone number to check on your port, I have just you this number to your Private Community Messages.
Check your Inbox.
HALIMACS
@KJM
Did you respond yes to the Port Authorization text when transferring to public mobile?
If so, try these following options just to be sure:
  1. Take off airplane mode
  2. take off do not disturb
  3. ensure the number calling you is not on blocked senders list
  4. disable any call-forwarding features
  5. turn off Bluetooth device if it's possible the 'ringing' is going through to it instead of device's speakers
  6. remove and replace your SIM card
  7. reset network connections
Following that, it could be a SIM provisioning (account) issue which you'll need support for.
  1. Use the ticketing system for a faster response time. Click here and type Customer Support Agent, then select contact Customer Support Agent, then select other (or the topic that more closely matches your request).  Click the result which states Click here to submit a ticket and follow the prompts,  or,
  2. Send a private message to the Customer Support Agent by clicking here  You’ll need to be logged into your Community account for the link to work.
cellphoneuser1
@KJM Does the Chatr sim still work? Maybe, the port didn't finish.
