06-03-2018 12:16 PM - edited 01-05-2022 04:51 AM
Hi everyone
I would like to know
Are incoming calls unlimited on all plans even with 10 dollar plan or what is the minimum plan to have unlimited incoming calls?
Thanks
06-03-2018 12:49 PM
There are also add-on minutes that you can buy. It won't make it unlimited, but you can add extra minutes to your account that won't expire:
Long Distance
$8 for 200 mins (US & Canada) and $15 for 400 International mins (includes US & Canada). Any unused minutes will roll over to your next cycle.
06-03-2018 12:42 PM
@prinzgill All other plans are unlimited incoming calls just except for $10 plan it just have 50 minutes counts for incoming & outgoing calls. If you need unlimited incoming calls for provincial wide is $20 & canada-wide is $30
06-03-2018 12:33 PM
@prinzgill There is a way to have unlimited incoming calls on the $10 plan but it's a bit convoluted. To wit, sign up at fongo.com and forward the PM number there to answer and take messages. Forwarded calls do not count toward the 50 minute limit.
06-03-2018 12:28 PM
@chrisc41 Those plans are provincial calling, not Canada wide, but do allow unlimited incoming calls from anywhere.
06-03-2018 12:27 PM
Incoming and outgoing calls count towards the same minute count. There are no plans that differentiate between the two. Hope this helps!
06-03-2018 12:25 PM - edited 06-03-2018 12:26 PM
No the 10 dollar plan only includes 50 incoming AND outgoing minutes. I believe the cheapest plan to include unlimited incoming calls would be the $20 which includes unlimited talk (incoming and outgoing), although if you need unlimited texts as well I would recommend going with the $25 plan which includes both.
06-03-2018 12:25 PM
I want to know about incoming calls not outgoing calls.
Thanks
06-03-2018 12:19 PM
@prinzgill wrote:Hi everyone
Thanks
No; on the $10 plan just 50 minutes total. Do you want Canada wide calling, or just provincial? Do you want texting and some data?
